#5 Postautor: cyber_human » sobota, 20 marca 2010, 00:01
A tu cytat z jakiegoś forum:
the electrical locker is installed free (parts and labour) in some European Countries (Spain, france, ...)
You can try to buy the "wiring kit" in your local Hyundai dealer.
The part number is: 91123-H1A00. It must be very cheap.
It will be easy to install it by an electricist.
Basically is an electrical switch that:
1) Disconect the transfer case electromagnetic clutch from TOD control unit.
2) Insert a load resistor to the output of the TOD Control unit.
3) supply 12v DC directrly to the electromagnetic clutch (lock)
4) supply a signal to the dashboard to indicate that you have the lock engaged.
We can help if you try to intall yourself.
Caution: the instalation implies to cut some wires. It must be cause to invalidate warranty if your dealer (or hyundai australia) does not recognize the problem.W razie czego pomoże Google Translator
I idąc dalej:
http://terracan.pl.pl/viewtopic.php?f=7&p=2010http://www.terracan.pl/4x4/4x4.htmledit: mogę zrobić tłumaczenie, jeśli potrzeba
SuperLock - pierwszy w Polsce
Chip:140@175 KM, 320@390 Nm
